Choppy Footage in Canvas from COMPACTFLASH CARD
Sharif Al-Haj
on Jan 26, 2012 at 8:33:48 pm
Hello,
I am working with a 32G Compact Flash Card and after transferring the footage to my Macbook Pro. I import the footage into my new Project in FCP. Whenever I click on the clip it comes up naturally in the Canvas viewer however it comes out choppy. Once I drag the selection of the clip to the timeline and render it, the footage works fine and seems to be smooth. Am I being tricked here or is this all right? how reliable is the canvas viewer window really?
All the Best!
Jeff Meyer
Re: Choppy Footage in Canvas from COMPACTFLASH CARD
on Jan 26, 2012 at 8:46:43 pm
1) Did you shoot using an SLR such as the 5D2, or 7D?
2) Did you convert the footage to ProRes before beginning the editing process?
(There are numerous pages detailing proper workflow for SLR cameras in Final Cut Pro)
3) Are you using the internal drive on your MacBook to edit? You need an external, Firewire based drive for editing.
Shane Ross
on Jan 26, 2012 at 11:44:23 pm
Use this workflow:
Tapeless Workflow for FCP 7 Tutorial
Shane
Little Frog Post
