Single image motion is very choppy
Filip Milovac
on Jan 26, 2012 at 2:36:36 pm
Hi, I have a little problem, finishing a video for a client and I added a few pictures from a shoot, did a simple motion with key frames on each side of the picture, but when I export the video the pictures and very choppy and not smooth. Please help, what do I do???
Scott Maida
Re: Single image motion is very choppy
on Jan 26, 2012 at 10:04:49 pm
I have the same issue, and I was just looking around the manual to see if I can find a solution..
good luck to both of us.
Filip Milovac
on Jan 27, 2012 at 12:07:18 am
If I find a way, will definitely post. Good luck to you too.
Filip Milovac
on Jan 27, 2012 at 10:58:35 am
Mate I use Premiere Pro, either way use high frame rate from the start, I think that could be the problem. Hope it works.
Scott Maida
on Jan 27, 2012 at 3:59:01 pm
Thanks. It worked fine after exporting to quicktime.... but how do you change the frame rate for future purposes?
