Render issues with
Maurice paramore
Render issues with
on Jan 20, 2012 at 7:10:49 pm
Hello,
I am working with Canon Dslr footage Apple pro res 1920X 1080 in final cut pro
When I apply my magic bullet looks effect, this message comes up when I try to render it....
"The effect "looks" have failed to render: Your hardware cannot render at the requested size and depth"
I'm not sure what this means or if I need to upgrade to something? Please if you know the problem let me know
I have an apple macbook pro... 2.4 Ghz Intel Core i5...Memory4GB 1067 MHz DDR3
Intel HD Graphics
Type: GPU
Bus: Built-In
VRAM (Total): 288 MB
Chris Tompkins
Re: Render issues with
on Jan 20, 2012 at 8:15:54 pm
Check you magic bullet settings, reduce the color bit depth if you can.
I have not used it.
Chris Tompkins
Video Atlanta LLC
Maurice paramore
on Jan 20, 2012 at 11:01:46 pm
Thank you for responding. I Can't change any of that with magic bullet. Is there any settings on Final cut maybe?
When I drop the video down to 720p it allows me to render it, but at 1080 it dosen't
Rafael Amador
on Jan 23, 2012 at 9:46:52 am
[Maurice paramore] ""The effect "looks" have failed to render: Your hardware cannot render at the requested size and depth""
Your GPU is not enough to render the effect at that size.
[Maurice paramore] "When I drop the video down to 720p it allows me to render it, but at 1080 it dosen't"
Right that.
rafael
http://www.nagavideo.com
Ewald Vorster
on Jun 11, 2012 at 8:59:35 am
I have the same rednder problem, but I have a Black magic Decklink HD extreme 3d card, But get the same render problem in FCP 7 when trying to render 1080 clips with MB Looks.
Im running 2x2.66 GHz-6 Core processor
16 GB Ram
Grapics is ATi Radeon HD 5770... is this not good enough?
When i downres to 1440 is works but yea.. but not what I want to export.
