Final Cut Express imported audio "pops"
Grant Vetters
on Jan 19, 2012 at 6:18:36 pm
My apologies, as I am sure this question has been asked before.
I have done some narration on a Tascam DR-100 using an Audio Techna mic with XLR inputs (irrelevant, but just for full details).
I have imported the .wav file into Final Cut Express. Initial playing of the file is perfect, but it appears that as soon as I trim off the head or tail, I get a pop/crackle at the beginning.
I have researched and found that .aiff files are best, so I converted the audio to that, and still exact same problem.
Does anyone have any suggestions/solution?
Much appreciated!
Andrew Rendell
Re: Final Cut Express imported audio "pops"
on Jan 22, 2012 at 11:56:25 pm
If you mean the click at the start & end of the clip as it passes the "play head", that's because frame based editing doesn't put the cut at a "zero" crossing point, so at the cut there's a high likelihood that there'll be a voltage jump, which translates aurally into a click. It won't happen every time, YMMV but it probably will something like half or three-quarters of the time.
The way to deal with it is either tweak the cut point in an audio suite (where you have sample accurate cutting) or add a fast dissolve to the cut (either keyframed or simply add a cross fade effect with a duration of 1 frame).
Grant Vetters
on Jan 25, 2012 at 11:50:04 pm
My apologies for the delayed response. I think you hit the nail on the head!
Thank you for taking the time to respond!
Grant
