viewer window is white
Robert Schmidtbauer
on Jan 11, 2012 at 10:30:24 pm
I have had this problem before and can't remember what I did to fix it! UGH! the viewer window is all white and whenever I put something into it, it won't show unless you play it, so when I put a jpeg or still in it I can't see it...I am sure it is some setting I have wrong, can anyone help or understand my babbling?
Shane Ross
Re: viewer window is white
on Jan 11, 2012 at 10:40:02 pm
#15 White or Black Canvas or Viewer
Shane's Stock Answer #15: White or Black Canvas or Viewer
Make sure the canvas or viewer are selected then go to VIEW>CHANNELS and set it to RGB. It might be set to ALPHA.
OR...
Click on the drop down menu above the Viewer or Canvas and make sure that you are on IMAGE or IMAGE + WIREFRAME.
Shane
Little Frog Post
Robert Schmidtbauer
on Jan 11, 2012 at 10:43:33 pm
Thanks Shane, the channels thing was it...Have a great day
