Black line issue in HD footage to SD DVD
Matt Surf
on Jan 3, 2012 at 9:35:59 am
Hi there,
I recently shot a massage film against a white background and I'm having difficulties compressing the footage for use on a DVD.
The film was shot in full HD using a Canon EOS 550D then compressed using Pro Res and edited out through FCP7. So far so good.
However, when I go through the usual Compressor settings for DVD Best Quality 90 minutes I get jagged edges on the lips of the subject when she talks plus other jagged issues.
So, I did a bit of surfing and created a new Compressor setting with Frame Controls set to Resize Filters: Better / Output Fields: Same as Source and Deinterlace: Better and Adaptive Details is ticked.
However, this option is creating faint black/grey horizontal lines across the white background of my encoded film.
Any help so I can get the best settings to stop either of these happening would be greatly appreciated. For info, both versions have been used on a Sony Blu Ray player on a HD Ready LCD TV which I assumes is trying to upscale the quality.
I also tried using Larry Jordan's settings and converted into Pro Res 422 HQ first but this just created a version where half the screen was black and the other section was weird pinks and green flashes (bizarre).
Thanks in advance for any help
Matt
Chris Tompkins
Re: Black line issue in HD footage to SD DVD
on Jan 3, 2012 at 11:56:55 pm
You don't mention how long the video is.
But, bluray upres to HDTV will not look the best.
Have you video the SD dvd on a DVD player to a SD tv?
Have you ticked up the data rate for more quality if you have the room.
Chris Tompkins
Video Atlanta LLC
Matt Surf
on Jan 4, 2012 at 1:22:26 pm
Hi Chris,
The film is around 20 minutes long so pretty lengthy. So far, I've only played the SDVD on a Blu Ray player so yeah, will auto upscale. You're right though, perhaps I should also try it on a normal DVD player.
Chris Tompkins
on Jan 4, 2012 at 2:24:41 pm
Ya u have a 90min preset w/20 min vid
Up the data
Chris Tompkins
Video Atlanta LLC
