XDCAM Transfer
Jan van den Heuvel
XDCAM Transfer
on Jan 2, 2012 at 5:53:15 am
When switching source I do get a message "Error Scanning Device". After "OK" it will load the clips and I don't see anything missing. To upload these clips into FCP7 I don't use the XDCAM transfer but upload directly. Is the error massage important or am I missing a plug-in in XDCAM 2.12.0 transfer.
Apple MacBook Pro 15"+Ext monitor with FCP7 and EX3 is used. See the screen shot for the full error message.
Dino Vince
Re: XDCAM Transfer
on Jan 5, 2012 at 7:03:13 pm
try downloading the XDCAM codecs for Final Cut from the Sony website.
Jan van den Heuvel
Re: XDCAM Transfer
on Jan 14, 2012 at 2:20:55 pm
Thanks for the suggestion
The clips do load into FCP without any errors I therefore imagine that the correct codecs are available. The error messages only pop up in XDCAM Transfer. The footage is visible and can be evaluated but when I save the changes it comes up with the second error message
The result of the problem is that when I make changes in clip evaluation in XDCAM Transfer I'm unable to save them and have to start all over next time around.
