AppleProRes HD to AppleProRes SD
aleksandar ljiljak
on Dec 28, 2011 at 12:07:49 pm
i tried to export AppleProRes HD to AppleProRes SD with Compressor (1h 35m long material), and for this operation compressor need a 42 hours!!!
Is it normal?
THNX
Aleksandar
MacPro2
2 x 2.66 DualCore Intel Xeon
6 Gb 667 DDR 2
FCP7
David Roth Weiss
Re: AppleProRes HD to AppleProRes SD
on Jan 1, 2012 at 12:16:08 pm
If you did the operation from the timeline it will take much longer than you'd imagine, especially if there are any unrendered clips. Scaling does after all require encoding every single pixel of every field or frame.
To save loads of time, first export a self contained file as your "master" using Export>>QuickTime Movie, without checking the recompress all frames checkbox. Then use that file in Compressor to create your SD version or any other file type you need.
The initial export from the timeline as I've mentioned above is very fast and makes an exact duplicate of your timeline without losing a generation, and the transcode from that exported file will still take a while, but not even close to 44 hours.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
