Reconnecting files
Andrew Pouch
Reconnecting files
on Dec 12, 2011 at 10:03:59 pm
Ok, so I started editing a project on one hard drive, and needed to transfer the project and all the files to another hard drive so someone else could edit the project. So I'm going at it reconnecting the files when all of a sudden a pop-up says something like "the clips have been altered, and reconnecting them will screw up the clips in the sequence"??? I'll try to reiterate...I think it's saying that the clips in the bin have been altered and the clips i'm trying to reconnect will mess up what I've got in the timeline. I'm not sure what to do...
Thanks in advance!
Andrew
Andrew Pouch
Re: Reconnecting files
on Dec 12, 2011 at 10:10:25 pm
"Some attributes of one or more of the files you have chosen do not match the attributes of the original. This may cause problems within the sequences that are dependent on them. The attributes that differed are as follows: -Media Start and End."
That's what it said.
Erick Puentes
on Dec 17, 2011 at 1:32:48 am
Not sure, but is it possible that not all your scratch disks are assigned to that project folder? If not, then some items might be floating in another folder that your original project was accessing.
~Erick
