Global FX To A Bunch of Clips?
Gabi Bucataru
on Dec 8, 2011 at 11:08:03 pm
Hi All!
I have a sequence filled with a lot of clips that are scaled differently, etc., and was wondering how can I add a global FX to the whole sequence - not just only to one clip.
The FX involves a vignette (besides color correction) that would not make sense on the scaled down clips, if that makes sense.
Is there a way to ad an "adjustment layer" much like you have in After Effects?
thanks,
gabi
Todd Gillespie
Re: Global FX To A Bunch of Clips?
on Dec 8, 2011 at 11:39:20 pm
No adjustment layer. But just like AE, you can pre-comp the sequence, then add the FX.
Good Luck,
Todd at UCSB
Television Production
Gabi Bucataru
on Dec 9, 2011 at 12:01:14 am
Thanks Todd...
but... I am still in the same dilemma in the precomp - suspecting that you are talking about nesting sequences... right?
thanks,
Gabi
Todd Gillespie
on Dec 9, 2011 at 12:07:36 am
No, I'm not sure I follow you?
If you nest the sequence, you will only need to apply the FX to the nest, which will include all the clips.
Try it first, to see if it does what you need.
Todd at UCSB
Gabi Bucataru
on Dec 9, 2011 at 1:58:28 am
Todd -
bingo! That did it.I did this before but when I double clicked the resulted clip in the time line, it brought me to the nested sequence instead o having it opened in the viewer. All I had to do is just that - right click and "Open in viewer" - an I was able to apply the fx -
thanks a bunch!
gabi.
