Problem when exporting in Final Cut
Gabriel Lahovary
on Dec 8, 2011 at 12:13:03 pm
Hello!
I have a problem in Final Cut. I had export my orginal files to ProRes 422 och started a new project. The Sequence are directly on 750x576. Then i started a new project and suddenly its 1920x1080. If i create a new seqcuene in the new project its 750x576 again. I worked a little bit in the first project untill i found out the sequence had the wrong format. Then a just copied the timeline clips and paste it in the new project. No move files are in the spider under/over the sequence, but my firend sad that i hadent have to import them in the new project. When im now finished and exported is look really strange, sometings wrong with the format. a little picture and a big black spot all aorund. Do you know what to do?
Chris Nguyen
Re: Problem when exporting in Final Cut
on Dec 10, 2011 at 8:07:25 am
Make sure your sequence settings (codecs) match your source codecs. You can see what codecs they are in the browser window if you scroll to the right.
Chris
