when ftg is same - when not to Chg seq settings to match clip settings?
Paul Dougherty
on Dec 2, 2011 at 9:21:30 pm
If I am making a sequence where 90% of the camera footage is the same, when would it be wrong to "Change sequence settings to match clip settings?" To match the dominant source material?
Paul
Chris Tompkins
Re: when ftg is same - when not to Chg seq settings to match clip settings?
on Dec 3, 2011 at 5:25:43 pm
Since you'll probably be fighting a render with the un-matched footage, you should go with what the most footage is.
Chris Tompkins
Video Atlanta LLC
