Quicktime video settings within Sequence settings...
Adam Heayberd
on Nov 28, 2011 at 10:07:46 am
I have a query regarding the QT settings within the seq. settings...
We shot a pilot programme on XDCAM. Originally the seq settings are set to pal 720 x 576 and the QT settings were: uncompressed 8-bit.
What we noticed between the viewer window and the canvas window was a slight degradation in quality of the video. In the viewer it looked as it should have been, crisp and with excellent definition but in the canvas window it looked slightly soft.
All the settings are correct to show the full res so when playing with the qt settings in the sequence settings, I changed them from uncompressed 8-bit to xdcam hd422 1080i50 and sure enough the canvas window started to display the footage as it should be and it matched the viewer window footage.
However, im now having to render alot of shots when I shouldnt normally have to.
Can anyone explain this or whether or not I have done the right thing? We play to xdcam deck but I dont want to loose quality in picture by reverting back to uncompressed 8-bit.
Regards
Adam
Editor & Self Shooter in the UK
http://www.aheayberd.tumblr.com
http://www.twitter.com/adamheayberd
Adam Heayberd
Re: Quicktime video settings within Sequence settings...
on Nov 28, 2011 at 10:16:19 am
Righto...have just changed the qt settings to:
APPLE PRO RES 422 HQ
Sure enough...it looks exactly how it should and I dont have to render every time i move a clip around.
Can i confirm I am now on the right wavelength with this??
Adam
Rafael Amador
on Nov 28, 2011 at 4:52:35 pm
Is your XDCAM 422 or 420?
What you should do is to open a new sequence, drop a clip, and when FC asks if you want to conform the sequence setting to the footage, hit YES.
That way you won't need to render nothing unless you apply filter on tweak something on the Motion tab.
If you have to apply filters or change something in the Motion tab, change the sequence codec to Prores.
rafael
http://www.nagavideo.com
