.prores Files
Phil Evans
.prores Files
on Nov 23, 2011 at 12:45:15 pm
Hello all
I have been sent some rushes and amongst the .movs are also .prores, .pcm and xml files. I was just wondering how I could have a look at the .prores files - I can't seem to open them in QT or FCP.
Any help would be much appreciated
Phil
Chris Tompkins
Re: .prores Files
on Nov 23, 2011 at 5:17:59 pm
Prores is native to apple. If you can't bring them into FCP, then something is really wrong with them.
What happens when you just double click the file @ the finder level?
Chris Tompkins
Video Atlanta LLC
Phil Evans
Re: .prores Files
on Nov 23, 2011 at 9:34:44 pm
Hi Chris
The files are actually .prores files, ie "filename.prores". The Mac sees it as a UNIX file, as it does when it doesn't recognise the file type. It seems that its the output from broadcast system with the audio and video as separate streams, not in a .mov container, if you see what I mean. I'm trying to get in contact with the guy who sent it to me but just wondered if there was a simple solution.
Kristel Ottis
Re: .prores Files
on Jun 25, 2014 at 3:21:24 pm
Did you ever figure out how to handle these files? I'm dealing with the same issue.
Chris Tompkins
Re: .prores Files
on Jun 25, 2014 at 3:32:34 pm
.prores for a file extension is new to me. Prores is the codec. They should be .MOV files.
What did your files from?
Chris
Phil Evans
Re: .prores Files
on Jun 25, 2014 at 3:23:30 pm
Sorry, don't remember if I found a solution for this or not.
