FCP 7 & RAM Question
Romeo Rubio
on Nov 23, 2011 at 12:18:59 am
I am currently cutting with Final Cut 7 on a 2010 i3 iMac with 4gb of ram. Since 7 is 32 bit, will I not see any performance improvements if I increase ram?
Shane Ross
Re: FCP 7 & RAM Question
on Nov 23, 2011 at 12:39:16 am
Nope! None. FCP sees 4GB of RAM and no more. Well, if you go to 8GB then FCP can use 4GB instead of whatever is leftover from what the OS is using of the current 4GB. But you won't see any vast improvement even going to 8GB.
Shane
Little Frog Post
