FCP exports wrong timing
Emils Latkovskis
on Nov 16, 2011 at 7:41:07 pm
when I play back my video in my project on sequence everything is perfect. But when I export video it exports wrong parts of the file...I get wrong timing from imported file. What might be the problem?
Using MacBook Pro and Final Cut Pro 7.
Neil Patience
Re: FCP exports wrong timing
on Nov 16, 2011 at 9:15:43 pm
When you say wrong timing do you mean just part of the sequence ?
If that is the case, make sure you do not have any in or out marks before you export or you will just get the marked section rather than the whole thing.
best wishes
© 2018 All Rights Reserved
