First off, you cannot install one copy of FCS on both machines. Well, you CAN, but you cannot run them at the same time. Copyright protection will stop that.
Second, you cannot open the same project on two machines at the same time. Well, you CAN, but it won't act like you think it will. IN fact, do that and most likely you'll crash, or corrupt the project file, or both.
There is no way to use two machines on the same project...much less with the same copy of the software.
Shane
Read my blog,
Little Frog in High Def
