Clear in and out in
David Cummins
Clear in and out in
on Oct 31, 2011 at 2:38:18 am
I have FCP Ver 7.0 and the "Clear In and Out" under the Mark menu is grayed out. To change in and out points of the source video, I have to delete the clip from my sequence time line and hunt for the same clip to set new in and out points. Very lame workflow! Is there a later version of version 7.0 that will allow me to adjust in and out points in the viewer? I don't want to use Ver X.
Thanks.
Rafael Amador
Re: Clear in and out in
on Oct 31, 2011 at 9:21:17 am
Alt-I will delete the IN, Alt-O the OUT and Alt-X both.
rafael
http://www.nagavideo.com
Olly Lawer
on Nov 14, 2011 at 11:30:47 am
You have to reselect the clip from the Browser, not from the timeline.
Then as Rafeal says above.
Kind regards,
Olly Lawer
