Out of Memory Issue
Mark Fanjoy
Out of Memory Issue
on Oct 23, 2011 at 7:13:10 am
Is there another reason I could be experiencing "Out of Memory" notices when I attempt a render, other than over sized still images, which I know can cause this?
I have plenty of RAM memory, usually about 8-9gigs showing. If I shut down FC and re boot, the problem usually goes away, but eventually creeps back in.
Sort of a side bar, during these conditions I will also get a big red "missing Codec" indication as well. Usually after a couple of render attempts, that one goes away. But re appears randomly.
Is there a Cache limit or something I don't know about?
Thanks.
Wherever I am...I'm lost!
Stephen Smith
Re: Out of Memory Issue
on Oct 24, 2011 at 4:33:58 pm
When I have gotten an Out of Memory notice I restarted the computer and everything returned to normal.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
jerry wise
on Oct 24, 2011 at 8:14:50 pm
i also get "out of memory" if i have my sequence set to "Video Processing" "Render 10 bit material in high precision YUV"
i usually set it to RGB or 8 bit YUV.
