iMac Log and Capture to Pro Res
Salvatore Consalvi
on Oct 22, 2011 at 9:52:29 pm
I have the iMac Intel Core i5 2.7 GHz, quad core (256 K, Memory: 8 GB) and 30 hrs of HDV tape to capture.
I'm using a Sony Deck and am having problems capturing. An editor says it may not have the computing power to handle it; and wants the work.
Is this true or can I break the capture into smaller (than hour tape) and work with it (identify dropped frames better) to get it in?
Or are there other tricks.
Rafael Amador
Re: iMac Log and Capture to Pro Res
on Oct 23, 2011 at 4:40:41 am
[Salvatore Consalvi] "I'm using a Sony Deck and am having problems capturing. An editor says it may not have the computing power to handle it; and wants the work"
This is being done since long with less powered macs.
Are you capturing to an external HD?
rafael
http://www.nagavideo.com
