Restoring Default Transitions - NOT WORKING
Steven Jones
on Oct 15, 2011 at 4:10:43 am
I accidentally clicked the "Clear Default Transition" feature in my Final Cut Pro, so I immediately found this link from CreativeCOW.net which I was sure would help me out:
http://forums.creativecow.net/thread/200/875855
Unfortunately, I follow each of these steps like it says, but when I go to right-click on the cross dissolve transition, it simply puts the dissolve into my timeline and that's it. I have tried numerous times in vain by following each of these steps, and yet every time I get to the end, it absolutely WILL NOT WORK and I find myself without my apple-T function.
And I "reset default transition" option NEVER darkens again, even when I am using the cross dissolve transitions.
Has someone else experienced this? If so, please share how you solved it.
Thanks in advance :)
