Importing Mpeg2 files into FCP
michelle marrion
on Oct 11, 2011 at 2:14:31 pm
Hello, I'm looking for the best way to work with mpeg2 files in Final Cut Pro. Does anyone know the best way to transcode them? The sequence will be using .mov and mpeg2 footage.
Chris Tompkins
Re: Importing Mpeg2 files into FCP
on Oct 11, 2011 at 2:22:16 pm
mpegstream clip
Chris Tompkins
Video Atlanta LLC
John Fishback
on Oct 11, 2011 at 8:34:47 pm
Don't mix codecs. It will make your editing life much easier. Convert everything to one codec. Pro Res is probably the best choice.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
