My Keyframe Motion Does Not Start at the beginning of the clip!
Efrain Schunior
on Oct 9, 2011 at 6:59:19 pm
Hello
I'm using FCP7 and i'm cross dissolving two clips. the later clip has keyframes that perform a basic zoom in. nothing fancy. the clip works fine on its own, but when i dissolve the two clips together all of a sudden the zoom will not start until the cross dissolve is nearly over, which looks terrible. any help?? i've TRIED to figure it out but it's making me nuts!!!!
many thanks
efrain
Neil Patience
Re: My Keyframe Motion Does Not Start at the beginning of the clip!
on Oct 11, 2011 at 4:30:47 pm
Hi Efrain
You can start the move before the shot starts.
Double click your clip in the timeline that you want to zoom so it loads into the viewer. Click the "motion" tab.
You should see the start and end keyframes of your zoom and the duration of the shot highlighted in a lighter grey colour.
Simply move the first keyframe so it appears before the start of the shot ie outside of the lighter grey area. Make sure you move it enough to take into account the duration of the dissolve and it will begin to move before the dissolve starts.
Hope that helps.
best wishes
Neil
http://www.patience.tv
