audio sync noob question
Gordon Neil Allen
on Oct 5, 2011 at 11:28:10 pm
Hi, a workflow question regarding audio sync.
On this shoot, a lot of the time there were two mics: one to the camera, one to a separate recorder.
It is more advisable to sync all mics, then edit?
Or edit first, then sync the 2nd audio source afterwards?
Thomas Morter-Laing
Re: audio sync noob question
on Oct 6, 2011 at 8:07:47 am
I would sync the mic first, that way it will all be there when you start moving bits around and cutting bits off- just make sure every time you cut a clip and move it you keep the off camera audio in sync!
A better alternative if your budget permits would perhaps be pluraleyes:
Great bit of software syncs audio for you- great if you have lots of clips!
Hope that all helps a little :)
Tom Morter-Laing
Freelance Editor,
Certified Apple Product Proffessional, 2010
Sony Z5, with Rode NTG2.
iMac 27" intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
© 2018 All Rights Reserved
