RENDERING issues
Ben Schramm
RENDERING issues
on Oct 3, 2011 at 3:51:19 pm
My job is to convert any ASF or AVI video files to MOV files so that I can edit them in Final Cut Pro (version 7.0.3)
In the past, there have been little to no problems with rendering, however, lately when I import the converted MOV file in to the timeline, FCP prompts a thick line render which takes multiple hours.
Is there anything that has been changed in the settings of FCP which would prompt a thick line render? If so, how the hell do I get it back to normal so I can render quickly and efficiently?
thanks in advance...
Rafael Amador
Re: RENDERING issues
on Oct 3, 2011 at 4:46:55 pm
[Ben Schramm] "In the past, there have been little to no problems with rendering, however, lately when I import the converted MOV file in to the timeline, FCP prompts a thick line render which takes multiple hours."
This is because the converted clips don't fully match with your sequence settings.
[Ben Schramm] "Is there anything that has been changed in the settings of FCP which would prompt a thick line rend"
Your export setting or your sequence setting do not match, so something has been changed somewhere.
[Ben Schramm] "If so, how the hell do I get it back to normal so I can render quickly and efficiently? "
Make sure your sequence setting are correct then use the same setting for the conversion.
rafael
http://www.nagavideo.com
Ben Schramm
on Oct 3, 2011 at 6:05:22 pm
When I attempt to import the clip in to the sequence, a box pops up stating THE CLIP DOES NOT MATCH SEQUENCE SETTINGS. CHANGE SEQUENCE SETTINGS TO MATCH CLIP SETTINGS? I click yes, and yet it still prompts a thick line render.
How do I go about changing the export setting or making sure the sequence is exactly matched up with the video's settings?
Rafael Amador
on Oct 3, 2011 at 6:37:28 pm
[Ben Schramm] "When I attempt to import the clip in to the sequence, a box pops up stating THE CLIP DOES NOT MATCH SEQUENCE SETTINGS. CHANGE SEQUENCE SETTINGS TO MATCH CLIP SETTINGS? I click yes, and yet it still prompts a thick line render. "
That's right.
You have to avoid to get that box and the only way is to match the stuff.
Your exports setting must match in:
- Codec
- Time-base (fps)
- Size
- Pixels aspect
- Field order.
Audio must be PCM 48Khz/16b.
Make sure that FC interprets (Browser) properly the clips settings.
rafael
