capture problems
Gail Blundell
capture problems
on Sep 28, 2011 at 6:51:24 am
I capture footage all the time without problem, I'm not very techo but I agree with the questions and it works fine this time when I capture now the footage slows down, and on replay it out of sync and cuts off to black after about two seconds, please help me I dont know why its doing it.
Chris Tompkins
Re: capture problems
on Sep 28, 2011 at 6:28:50 pm
Your post is confusing and lack crucial details on your settings/formats/codecs
What are you capturing from?
Chris Tompkins
Video Atlanta LLC
Gail Blundell
on Sep 30, 2011 at 4:22:38 am
Hi Chris thanks for getting back, I am capturing from aBDV1808i Sony
I have done it this way for years, but I don't know what has changed.
The capture settings are apple firewire.DV Pal 48 I'm in Australia
It captures sort of jerky and then after 2 sec goes black, then tells me about time codes, time codes are not important to me as I only capture now.
Another project I am working on (which was fine) now won't play on the timeline, it stalls and jumps
The only thing I changed was the scratch disk as I added a new storage disk.
I moved files around onto the new disk, all this started at the same time sorry to sound vague but I only use FCP for this one thing and don't know what I may have done to change things.
Any ideas would help I will try them all, I don't use the Mac for anyting else so it is a mystery to me.
I also have a problem with the HDD it tells me to run repair disk but its not lit up so I can't.
Thanks again, I'm lost as it has never given me any grief before.
Gail
Chris Tompkins
on Sep 30, 2011 at 10:25:02 am
It sounds like you have a dying hard drive.
If you cannot run a repair on it, it might be gone for good.
Always backup files b/c drives will fail.
Can you try a new drive?
Chris Tompkins
Video Atlanta LLC
Gail Blundell
on Oct 3, 2011 at 12:27:26 am
Hi chris, thanks again, do you mean start the mac from a new drive, I have just bought one I will need to get someone in to help me with this, thanks again for you help, it is great that people are willing to give their time to help strangers really appreciated.
Regards
Gail
