Use 422 LT for Sony NEXVG10 Transfer?
Mark Fanjoy
on Sep 27, 2011 at 3:19:06 pm
I want to ingest footage shot on my Sony NEXVG10 into FC. I want the closest lossless output I can achieve going to Blu-Ray.
Is the ProRes 422(LT) codec plenty for me to use to ingest from this camera? Do I really gain anything (other than twice and three times the file size!) using 422 or 422(HQ)?
I recall reading somewhere that depending on the BIT rate, it is a waste of space to ingest with a higher codec when the lower codec will capture a lossless picture just fine.
Thanks in advance for a clarification.
Wherever I am...I'm lost!
Rafael Amador
Re: Use 422 LT for Sony NEXVG10 Transfer?
on Sep 27, 2011 at 5:20:22 pm
Everything down from Uncompressed down degrades the picture.
You may see it or not, but compression is there.
[Mark Fanjoy] "I recall reading somewhere that depending on the BIT rate, it is a waste of space to ingest with a higher codec when the lower codec will capture a lossless picture just fine."
That statement goes against all the laws of the physics .
If a low data-rate is enough, why to bother in adding higher data-rate options?
What are for Uncompressed options?
There is trade data-rate/quality; is to you to chose what is more convenient for your workflow, but be aware of the pros and cons.
Best,
Rafael
http://www.nagavideo.com
