Logging .mov footage
Raj Trivedi
on Sep 23, 2011 at 7:42:19 pm
Any suggestions on how to log .mov footage in fcp? I created a batch list but can't get the batch list and the .mov footage to sync. I presume there is a simple solution, but couldn't find anything about it on the threads :( . I tried log/capture, log/transfer, batch capture, but none of those ways work.
I was given a dvd from which to use the footage, the format was video_ts, then converted to .mov and that's the file i need to log. Any help would be awesome!
Chris Tompkins
Re: Logging .mov footage
on Sep 23, 2011 at 9:45:40 pm
You rip the DVD to .mov files.
IMPORT them.
You do NOT L&T or L&C quicktime files sitting on your system already.
Chris Tompkins
Video Atlanta LLC
Shane Ross
on Sep 23, 2011 at 11:54:53 pm
Specifically, you use MPEG STREAMCLIP to rip the DVDs and convert them to DV/NTSC...or DV50.
You have to encode to an EDITING codec...editable format of .mov.
Shane
