convert 24 fps to 30 fps for XDCAM export
paul LaRoche
on Sep 19, 2011 at 8:47:04 pm
I am trying to creating an MXF file via XDCAM export, does this require video to be 30 fps? If so, how do I convert from 24 fps to 30 fps? Someone mentioned a 3:2 pulldown conversion. What is this?
Laura Wood
Re: convert 24 fps to 30 fps for XDCAM export
on Sep 22, 2011 at 8:49:06 am
As for your 3:2 pulldown conversion. Here's detailed info:
Film runs at a rate of 24 frames per second, and video that adheres to the NTSC television standard runs at 30 frames a second. When film is converted to NTSC video, the frame rates need to be matched in order for the film-to-video conversion to take place. This process of matching the film frame rate to the video frame rate is called "3:2 pulldown."
Laura
Laura Wood
