Output from timeline to dvd drive.
Sabrina Ramdass
on Sep 17, 2011 at 2:56:53 am
Hi using final cut pro 4 I have some footages in the timeline which I would like to output to the DVD drive.
Please drop me a line if this is possible.
Rafael Amador
Re: Output from timeline to dvd drive.
on Sep 17, 2011 at 8:23:36 am
Hi Sabrina,
Yes, Is possible, but you need a DVD recorder able to record in real time.
Google "DVD real time recorder".
rafael
http://www.nagavideo.com
Chris Tompkins
on Sep 18, 2011 at 3:26:52 pm
Either you have an I/O card where you can play the sequence out in realtime to an ext. DVD recorder OR you export your sequence "Current Settings" to a file and compress that to DVD files and create/burn a DVD on your comp.
Chris Tompkins
Video Atlanta LLC
Rafael Amador
on Sep 18, 2011 at 4:25:04 pm
[Chris Tompkins] "Either you have an I/O card where you can play the sequence out in realtime to an ext. DVD recorder "
Most accepts FW.
rafael
Andrew Rendell
on Sep 19, 2011 at 8:20:50 am
I usually just export the sequence onto my desktop and use the "OneStep DVD from movie..." option in iDVD to make a DVD.
