I think I need assistance learning lens flares
Raj Shah
on Sep 14, 2011 at 11:29:36 pm
I'm trying to replicate the lighting effects of this ad
you can see at the 45 second mark. I think it's a lens flare, but can't tell. How on earth would I even begin trying to replicate that? I don't have a lens flare of my own, which I think I need, according to some website I saw. Can anyone help?
Rafael Amador
Re: I think I need assistance learning lens flares
on Sep 15, 2011 at 8:15:45 am
FCP has a Lens Flare.
Look in the Generators > Renders.
I think that in the MOTION contents use to be something also.
rafael
http://www.nagavideo.com
Jeff Meyer
on Sep 16, 2011 at 2:17:42 am
There's Motion's flare generator or Video Copilot makes "Optical Flares" for After Effects if you need some extra horsepower.
Dennis Leppell
on Sep 22, 2011 at 5:08:17 pm
I'm assuming you are looking to replicate the lens flare AND the transition. It's two seperate components that are pretty easy to break down.
First is a default FCP lens flare, with most of the settings turned off, to look like a spotlight.
The transition is a light leak transition, possibly home made. Search vimeo, there's a few available on there free to download.
The clip following the transition has the same default lens flare, just a bit bigger.
Most the other flares look like they came from Video Copilot, or were hand made and composited.
Good luck!
