Can I change aspect ratio on video?
krystallia sakellariou
on Sep 14, 2011 at 6:30:34 pm
I am working on a video sequence and wonder if anybody knows if it's possible to change the aspect ratio on my video so that it gets squared 1:1 ( or preferably 3:4 (not 4:3). Is it possible to do this in Final Cut, or do I need another program?
Hope somebody can help me.
Thank you!
Krystallia
Chris Tompkins
Re: Can I change aspect ratio on video?
on Sep 14, 2011 at 7:58:53 pm
Double Click your clip.
Under Motion Tab.
Distort Section.
Aspect Ratio.
Chris Tompkins
Video Atlanta LLC
Miguel Guerrero
on Apr 30, 2012 at 5:42:20 pm
Can I do what you suggested in Final Cut Pro X or just in the older versions? I donĀ“t find the Motion Tab, nor the Sequence settings in Final Cut Pro X. :(
Stephen Smith
on Sep 14, 2011 at 8:00:36 pm
Go to Sequence, Settings, and change the Aspect Ratio to Custom. YOu can make any Frame Size you want. Be prepared to do lots of rendering. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
on Sep 15, 2011 at 2:16:41 pm
Thank you both! It works fine now:-)
Stephen Smith
on Sep 15, 2011 at 3:25:04 pm
That's great. Best of luck.
Stephen Smith
