about final cut pro basic
Yusuf Lateef
on Sep 6, 2011 at 11:11:03 am
hello everybody
can anyone guide me in this ?
is it neccesary to render every clip in FCP ?
if u wanna go fast then how to edit movies in FCP ?
Shane Ross
Re: about final cut pro basic
on Sep 6, 2011 at 1:44:39 pm
[Yusuf Lateef] "is it neccesary to render every clip in FCP ?"
Only if the footage you are importing isn't a format that FCP is designed to work with. FCP has a list of codecs it edits...that can be found in the EASY SETUP menu in the Final Cut Pro Menu. If your footage isn't listed, then you need to convert it to one of those formats. When you do that, then FCP will make sequence settings that match...and you will have no rendering.
[Yusuf Lateef] "if u wanna go fast then how to edit movies in FCP ?"
Convert footage to match. Or use another editing app that doesn't require you to convert the footage.
Shane
Yusuf Lateef
on Sep 6, 2011 at 1:56:01 pm
thanx boss ur advice helped me a lott
A CREATIVE GUY FROM INDIA
