FCP 7 Sequence Setting Question
Nathan McKay
on Sep 5, 2011 at 9:27:01 pm
Hello,
I shoot with the Canon 5d Mark II, and my sequence setting tab "Compressor" is using Apple ProRes 422. I know others use H.264 for this setting, but I have a question: what is the difference? I accidentally switched over to this from using H.264 and nothing seems to have changed. So I'm wondering what the difference is....
Shane Ross
Re: FCP 7 Sequence Setting Question
on Sep 6, 2011 at 9:01:44 am
Don't edit the h.264 files natively with the camera with FCP 7. YOu need to convert to ProRes. I have the workflow for that here:
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
Shane
