Transition woes
Laurie Patton
Transition woes
on Sep 1, 2011 at 9:22:46 pm
I have a very simple lower third with a solid back at about 40 opacity.
At first when I tried both cross dissolve or fade in fade out first the words would come up and then the bar would pop in. I solved that problem through trial and error.
But, now the front fade in is just too fast. More of a pop in than a fade in. Fade out is just fine.
I've tried extending the time and that doesn't work. Any help would be super appreciated.
Thank you! Laurie
Jeff Greenberg
Re: Transition woes
on Sep 3, 2011 at 2:51:35 am
How about nesting the lower third and solid back into it's own sequence (opt-c) then fading that up/down?
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Compressor Essentials from
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from
Contact me through my Website
Miriam Lefkowitz
Re: Transition woes
on Sep 3, 2011 at 3:36:00 pm
When I can't get the transitions to work the way I want I'll use the pen tool instead and work directly on the video overlay line in the timeline, using keyframes to fade the clips in and out, not the cross-dissolve filter.
© 2018 All Rights Reserved
