Importing DVD footage - interlacing?
Steve Ward
on Aug 28, 2011 at 12:14:03 am
Hey Guys,
I'm attempting to import some footage of a band into a doc that I'm working on.
The bulk of the doc was shot on XDCAM EX which has been converted to ProRes.
Settings for my project:
1920 x 1080 HDTV 1080i (16:9)
23.98 fps
XDCAM EX 1080p24 35 Mb/s VBR
About the DVD footage from MPEG Streamclip:
Stream: VTS_01_1.VOB
Path: /Volumes/HLG/VIDEO_TS/VTS_01_1.VOB
Type: VOB program stream
Duration: 0:03:56
Data Size: 214.35 MB
Bit Rate: 7.60 Mbps
Video Tracks:
224 MPEG-2, 720 × 480, 16:9, 29.97 fps, 8.00 Mbps, lower field first
Audio Tracks:
128 AC3 2/0, 48 kHz, 192 kbps
Stream Files:
VTS_01_1.VOB (214.35 MB)
Anyhow, I'm trying to import the footage from the DVD but it always looks like this:
I've tried directly importing into FCP and also tried converting it with MPEG Streamclip first.
Any suggestions would be appreciated. Thanks.
Jeff Greenberg
Re: Importing DVD footage - interlacing?
on Aug 28, 2011 at 5:10:55 am
Well, you're bringing interlaced clips into a deinterlaced timeline. Have you tried deinterlacing it?
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Andrew Rendell
on Aug 28, 2011 at 8:29:14 am
As well as deinterlacing, it'll be better to cut with if it's 24fps to match the rest of your material, so I'd do both the deinterlace and the frame rate change with MPEG Streamclip to see what the quality's like (there are other ways to go about it, but your quality is already compromised by coming from a DVD).
Chris Tompkins
on Aug 28, 2011 at 4:17:37 pm
When you rip the disc in MpegStreamClip - select "Deinterlace"
And ProRes.
Chris Tompkins
Video Atlanta LLC
