Rendering in FCP vs. Premiere
Mark Mallett
on Aug 25, 2011 at 11:04:03 pm
I am testing out Adobe Premiere 5.5. The first thing I noticed is when I add a filter or effect (from a third party like Sapphire eg.), Premiere plays it back without needing rendering!! But in FCP, every stinking little thing I do has to be rendered. My Sequence/footage settings are correct, so basic playback doesn't require rendering. But it's when I add effects that FCP becomes an exercise of watching a progress bar 90 percent of the time.
I thought FCP, especially v. 7, which is what I'm using (FCP Studio 3), allowed you to view clips without having to render them? FCP X does, Adobe does, but not FCP 7. Are my settings wrong, or is this simply how the software works? Is there something I can change?
Shane Ross
Re: Rendering in FCP vs. Premiere
on Aug 25, 2011 at 11:49:10 pm
Only certain FXPlug effects in FCP 7 don't require rendering to view. And they depend on the graphic card you use. But Adobe has ALWAYS been better about filters and rendering...
Shane
Mark Mallett
on Aug 25, 2011 at 11:50:27 pm
I was afraid you were going to say that. Maybe it's time to leap over to Premiere for good....
Emanuel Ach
on Aug 26, 2011 at 7:47:38 pm
premier has only um 4 cams multiclip max ;)
just to let you know
