Workflow for editing footage from a 60 D shot on high speed
Roxanne Britten
on Aug 17, 2011 at 6:21:44 am
Hi
I am currently editing on Final Cut Pro 7 and would like to know what the best workflow would be, if i was to edit footage from a 60 D camera, all shot on high speed. Coming from Log and transfer to the actual editing of the footage, which would be the best editing format and which would the best quality to export the completed sequence?
Thank You
RB
Chris Tompkins
Re: Workflow for editing footage from a 60 D shot on high speed
on Aug 17, 2011 at 3:37:17 pm
Well, the 60D does not shoot Variable Frame Rate (VFR)
So, you can shoot:
24,(25,50) 30, 60 FPS Did you shoot 60fps? Is this what you mean by shot hi-speed?
You can shoot @ 60 and conform/edit @ 24 and this will give you slo-mo.
Perhaps more details?
Watch the tutorial here on the cow on tapeless workflow.
Shoot video.
Bring it into FCP via L&T.
Edit.
Chris Tompkins
Video Atlanta LLC
Shane Ross
on Aug 18, 2011 at 12:48:23 am
SMOOTH SLOW MOTION FROM 60P USING CINEMA TOOLS
http://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
Shane
