Broadcast Safe Images
Tamarind Nott
on Aug 8, 2011 at 7:47:28 am
I need to make my images broadcast safe- there were a few hot spots on our actors heads where the light was set too bright. I know that a yellow exclamation mark indicates that either the luminance or the chroma is a problem, but how do i know which is the problem? And how do I fix it?
Any help appreciated!
Everest Mokaeff
Re: Broadcast Safe Images
on Aug 8, 2011 at 10:42:54 am
Use broadcast safe filter. If you need to fix footage in regard to color/exposure use filters for color correction. There is no need for guesswork - use scopes to read and analyze data from footage to make informed decisions.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
