Changing Audio from 32-bit floating point to 16-bit
Floyd Mathis
on Aug 2, 2011 at 11:32:15 am
Hi All,
Im pretty new to FCP ( I'm using version 7 ) & looking for some help
I need to output a movie file as:
Quicktime .mov
ProRes 422LT
25 fps
Interlacing Field: Upper / top field first
Audio SD: 16-bit
Audio SF: 48KHz
So in sequence settings..on the General tab i have 16-bit selected on the Audio settings
After i send to compresser, i open the file i've made in fcp to check the info on it and it says the audio is 32-bit floating point
can this be changed to 16-bit and if so how ?
Any help much apreciated
Floyd
