Capture settings for DV
Brian Harder
on Aug 1, 2011 at 10:56:45 pm
When capturing footage into FCP record in SDI, and recorded onto a DVCam deck, what Capture setting should I use?
I’ve been using 525i29.97 8 bit (720x486). But should I use 720p59.97 8 bit (1280x720) to capture it at the best setting? Or is that just creating a big file, with no improved quality? The final output is for the Web.
Thanks.
Brian -
Everest Mokaeff
Re: Capture settings for DV
on Aug 2, 2011 at 11:41:24 am
You can't capture w/ 720p preset from DV tape. BTW, if you want best quality use FW for DV capture instead of SDI.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
