Compressor Dimension problems at 25% of source
Matt Cohn
on Jul 29, 2011 at 7:42:13 pm
I've run into a problem with dimension settings in Compressor 3.5 and I haven't been able to figure out where the problem lies. I am trying to compress a 1440 x 1080 self-contained QT file (MPEG-2 created from an HDV sequence in FCP) to an mp4 at 480 x 270. I usually do this by setting the dimension size in Compressor to 25% of source. This time, though, I changed the dimension to 25% of source, and I kept getting a size of 360 x 270. Is there a setting in Compressor that needs to be changed to get the dimension size settings to work correctly?
Matt
Dan Mansfield
Re: Compressor Dimension problems at 25% of source
on Jul 29, 2011 at 11:30:18 pm
The math compressor is doing is correct, 25% of 1440x1080 is 360x270.
If you would like the outputted size to be 480x270, change the frame size in the Dimensions section to Custom (not 25%), then enter in 480x270.
Dan Mansfield
Point7West
http://www.point7west.com
