Keyboard shortcuts
Danielle May
Keyboard shortcuts
on Jul 19, 2011 at 11:21:20 pm
I just started a new job and they want me to learn keyboard shortcuts for final cut pro, so that I will be a faster editor. I was wondering if someone could let me know what are the most important keyboard shortcuts to know for final cut pro. Thank you.
Everest Mokaeff
Re: Keyboard shortcuts
on Jul 19, 2011 at 11:36:44 pm
Command S is my number one of all times.
Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
http://www.mokaeff.com
Mark Suszko
on Jul 20, 2011 at 1:35:57 pm
Best thing we added to our FCP suites were dedicated keyboards with all the shortcuts printed on the keys. If you can't afford one, you can get a keyboard "skin" with the buttons labeled for something like $30. If you can't afford that, you can go with stick-on key labels, either purchased, or home-made. Or print out a chart from the manual, and hang it under the monitor.
Karl Hans e Greuy
on Jul 21, 2011 at 7:32:32 pm
A skin would probably be the cheapest and easiest. The most important ones are simple, and done in alphabetical it would seem.
"A" =Arrow
"B" =Blade (double tap for double blade)
"C" =Crop tool
"P" =Pen tool
"Z" =zoom in (double tap for zoom out)
For me I just think Arrow-A, zoom-Z and so on.
Cut and paste are the same as in everything else.
There are more and you will pick them up over time, I would recommend buying a skin rather than the specifically designed keyboard as once you are used to them you will not look at keyboard again. Think about how you first started typing you were probably looking at the keyboard all them time now it probably second nature to you, the same will happen with the shortcuts, so in my opinion it's not worth spending money on a new keyboard.
Here is a full list http://www.nobledesktop.com/shortcuts-finalcutpro5-mac.html
And as mentioned above "Option S" the most important one you'll need.
Hope this helps a little.
Karl Hans e Greuy
on Jul 21, 2011 at 9:40:02 pm
Oops that was supposed to be "Command S" to save sorry for that.
Danielle May
on Jul 21, 2011 at 9:46:10 pm
Thanks for all the help!
