Import data from spreadsheet.
Daniel Kwiatkowski
on Jul 11, 2011 at 7:20:10 pm
I have a few questions about manipulating data in the bin view.
First: Let's say that I want to copy all of the data from the clip name column into the description column (or vice versa) Assuming that I had several hundred clips is there any easier way of doing this than selecting the data in one field cmd+C, select the data in the other field cmd+V? Essentially I'm looking for a way to copy the data from one column to the next.
Second: Is there an easy way to import data from a spreadsheet program into the description columns without manually copying and pasting each entry? Right now the descriptions are in either an excel spreadsheet or a filemaker database (which I assume can probably be output as a spreadsheet)
This isn't super urgent, I won't be working on the system until Wednesday. All responses are very much appreciated!
