1440*1080 versus 1920*1080 - Canon T3i vs SONY EX1
Sascha Engel
on Jun 23, 2011 at 10:22:28 am
A very strange question, I know:
I am editing footage of two different cameras together: SONY EX1 (Full HD mode) and from the DSLR Canon T3i.
After Transcoding all the material to ProRes, I am surprised to see that the Canon material is 1920*1080, but the EX1 material 1440*1080.
How come ? Both is HD Widescreen material. I never understood, what is the 1440*1080 anyway. How can it be the same proportion of Widescreen Canvas, when it has same height, but missing 480 pixels in Width?
Help me to shed some light on this!
Thanx.
Sascha
Rafael Amador
Re: 1440*1080 versus 1920*1080 - Canon T3i vs SONY EX1
on Jun 23, 2011 at 10:43:30 am
[Sascha Engel] "After Transcoding all the material to ProRes, I am surprised to see that the Canon material is 1920*1080, but the EX1 material 1440*1080.
How come ? Both is HD Widescreen material. I never understood, what is the 1440*1080 anyway. How can it be the same proportion of Widescreen Canvas, when it has same height, but missing 480 pixels in Width?"
Sascha,
You shot with the EX set to "SQ" instead of "HQ".
EX/SQ is plain HDV: 1440 x 1080 HD/Pixels. 25Mbps/LongGOP/MPEG-2/8b-420-YUV.
That is not "Full raster HD".
The "Full Raster HD" mode is the "HQ" : 1920x1080 Square Pixels/ 35Mbps......
rafael
http://www.nagavideo.com
Jeff Pulera
on Jun 23, 2011 at 5:48:04 pm
1920x1080 HD video uses square pixels, with a Pixel Aspect Ratio of 1.0, while 1440x1080 "Anamorphic HD" uses rectangular pixels with a PAR of 1.333. Because the pixels are wider than they are tall, it still fills the 16:9 screen area, and simple math proves it, as 1440 x 1.333 = 1920.
Whether working in a 1440x1080 or 1920x1080 Premiere Sequence, you can mix the two formats together, your choice of what mode you wish to edit in. Just try to match frame rate when shooting, for instance both 1080i 29.97, or both 1080p30.
Jeff Pulera
Safe Harbor Computers
Jeff Pulera
on Jun 23, 2011 at 5:49:13 pm
Forgot I was in the FCP forum and not Adobe, the specs are still true though.
Jeff
Sascha Engel
on Jun 23, 2011 at 6:01:30 pm
Hi man,
Thanx for a chrystal clear answer! And about Premiere- it's the app I started on! And unfortunately might return to again after the FCP X disaster!!!
Chris Tompkins
on Jun 24, 2011 at 10:47:05 am
You can drop that 1440 material right in the 1920 sequence and it'll be fine.
There are so many settings and buttons on today's cams, it's an easy mistake.
Chris Tompkins
Video Atlanta LLC
io iezzi
on Apr 6, 2012 at 2:19:13 am
Hi I need help changing my aspect ratio in final cut
Sascha Engel
on Apr 6, 2012 at 2:57:38 am
Please, specify ur Q. Changing from what to what?
io iezzi
on Apr 6, 2012 at 3:06:35 am
I have imported footage into fcp. the original files are 1080/1920 but my fcp settings were 720/576.
I have changed the frame size in system settings to 1080/1920 but the aspect ratio won't change and now my footage doesn't fit the screen????
Sascha Engel
on Apr 6, 2012 at 5:08:08 am
One is 4to3, the other 16to9 format.
Only way is to letterbox it if it has to fit 4to3 ratio.
Juan Salvo
on Apr 6, 2012 at 5:50:08 am
Right-Click on the clip in the sequence and "remove Attributes" then check basic motion & distort.
