Qmaster setup
Jesse Austin
Qmaster setup
on Jun 21, 2011 at 3:12:22 am
Hello out there...
Ok can someone help me out please? What is the proper way to set up Qmaster and how do I know it is working correctly? The comp is a 2x2.66 6 core Intel with 20 gigs of ram. So I have heard that you will setup QuickCluster with services, check share and managed. Since there is 20 gigs of ram you would select 19 instances leaving 1 gig for background stuff to continue.
So up in the menu bar I see the Qmaster icon with all 19 instances listed. Now when I start compressing a video file in Compressor after selecting the QuickCluster I just created, I never have seen all 19 lite up green, only a few will show being captured. Why is this?
Any help would be nice...
Jess
Rafael Amador
Re: Qmaster setup
on Jun 21, 2011 at 10:42:20 am
[Jesse Austin] "Ok can someone help me out please? What is the proper way to set up Qmaster and how do I know it is working correctly? The comp is a 2x2.66 6 core Intel with 20 gigs of ram. So I have heard that you will setup QuickCluster with services, check share and managed. Since there is 20 gigs of ram you would select 19 instances leaving 1 gig for background stuff to continue.
So up in the menu bar I see the Qmaster icon with all 19 instances listed. Now when I start compressing a video file in Compressor after selecting the QuickCluster I just created, I never have seen all 19 lite up green, only a few will show being captured. Why is this?"
I thinkthat the top number of instances you can set, is the same of the processors/cores you have.
The RAM works different, normally is recommended 2GBs RAM per processor/core.
rafael
http://www.nagavideo.com
Jesse Austin
Re: Qmaster setup
on Jun 22, 2011 at 3:00:03 am
Hey,
What do you mean 2gigs per core? Since there is 12 cores I should be set up with 24gigs of ram?
Jess
Rafael Amador
Re: Qmaster setup
on Jun 23, 2011 at 9:31:39 am
Right.
That's the minimum recommended RAM.
rafael
