FCP - create gaps between clips according to time code
Miha Kokalj
on Jun 10, 2011 at 8:52:22 am
I have a bunch of clips with camera time code. Is there a way to place them in a sequence so they have gaps when the camera wasnt filming?
example: camera shuts off for one minute, there is a gap of 1 minute between two clips
Shane Ross
Re: FCP - create gaps between clips according to time code
on Jun 10, 2011 at 8:22:58 pm
By manually cutting them into the sequence. There are still things you have to do manually. Editing isn't automatic.
Shane
Jeff Greenberg
on Jun 12, 2011 at 5:00:02 pm
Try selecting all the clip and choosing "Make Mulitclip Sequence" - make sure you pick using Starting timecode (and this only really works if you used time of day timecode.) A sequence will be built based on that timecode.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
