Pan Audio Center
Andres Rios
Pan Audio Center
on Jun 9, 2011 at 11:44:31 pm
I have a whole sequence with audio which only comes out one channel. Panning the audio to the center solves his issue however, what’s the fastest way to do this? Is there a filter that does this or do i need to go to every individual clip and pan the audio?
Cody Walters
Re: Pan Audio Center
on Jun 10, 2011 at 1:45:32 am
Fix the pan issue with one of your clips. Then select the clip, copy the clip, then highlight all other audio clips and perform the paste attributes function. Paste the Pan attribute and you should be good to go.
Cody Walters
JW Studio LLC
Houston Video Production
Houston Wedding Videographer
Final Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7D
Andres Rios
on Jun 10, 2011 at 4:18:59 am
Andrew Rendell
on Jun 10, 2011 at 5:40:58 pm
Or select all your clips on the timeline and press {Control} and {full stop} together.
Tim Short
on May 15, 2012 at 11:09:17 am
Brilliant that !
Be a bit kinder
Jeff Greenberg
on Jun 11, 2011 at 5:29:50 pm
Select the track with the T key.
Modify Menu> Audio> pan Center (CNTRL . )
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from
Contact me through my Website
© 2018 All Rights Reserved
