AVCHD - Log & Transfer
Adam Burrows
on May 30, 2011 at 9:58:44 am
I've been attempting to use log and transfer to import some HD footage. It detects the footage and plays it correctly, however, when I import it and play it back, the right third of the frame is cropped off. When I play the footage in the log and transfer window, it is not cut off, however, it is once it imports to the browser. Is there any way to fix this?
Chris Tompkins
Re: AVCHD - Log & Transfer
on May 30, 2011 at 3:23:12 pm
Did you view the "Tapeless Workflow Tutorial" here on the Cow?
What are your settings on the clips in the browser?
What are your sequence settings?
Chris Tompkins
Video Atlanta LLC
Adam Burrows
on May 30, 2011 at 5:12:12 pm
I have reviewed the tutorial, but it did not help. The clips are Apple ProRes 422 (1440x1080). The sequence matches these settings, however the clips appear cropped (and stretched) before they are in the sequence.
