Setup 12-core with Q-master
Brandon Morris
on May 26, 2011 at 8:27:47 pm
I got a 12-core, very excited.
What's the best way to setup Q-master to use all 12 cores?
Brandon Morris
http://www.brandonmorris.com
Canon T2i
13" Macbook Pro (Mid 09) 8GB RAM 10.6
Eric Strand
Re: Setup 12-core with Q-master
on May 26, 2011 at 10:42:39 pm
You won't want to use all 12 cores, from what I've read the rule of thumb is about half the number of cores you have. You also want to make sure you have 1GB of ram per core.
Brandon Morris
on May 26, 2011 at 10:59:26 pm
What about the no. of threads? It says 24, so I should only use 12 threads?
Brandon Morris
Canon T2i
Eric Strand
on May 27, 2011 at 1:38:05 am
To be honest, I'm not sure. I've only ever adjusted the number of cores. Here is an article on it. http://www.kenstone.net/fcp_homepage/compressor_multi_cores_stitzer.html
Brandon Morris
on May 27, 2011 at 11:03:09 pm
Is it worth using other networked computers' cores?
Don't they take longer bc it's pulling the content to render from the main computer that is rendering as well?
Brandon Morris
Canon T2i
Eric Strand
on May 29, 2011 at 3:27:50 am
I haven't used other networked computers, but I that may be more trouble than it is worth. I have read that Qmaster can be shaky, sometimes my virtual cluster shows up, sometimes it doesn't.
Chris Cea
on May 27, 2011 at 4:31:38 pm
Brandon, give this link a look.
http://www.digitalrebellion.com/blog/posts/using_compressor_with_multiple_c...
